Choice of aftermarket cam rockers
I have gotten some very small pitting on one of my rocker arms. The area where the pitting occurs are typically where the cam touches the rockers at max lift.
To remedy this I am thinking of buying new aftermarket racing rockers. So I have been looking at a couple of brands. First the forged DLC rocker arms from Schrick and then the billet tool steel DLC rocker arms from Pauter. I would be very happy for input from you guys in here on what to choose ![]() Regards Eskild Sent from my iPad using Tapatalk Last edited by Litle brother; 05-21-2019 at 03:56 PM.. |
Hi Eskild.
i am working with some few sets in titanium if its intresting? i think price will be almost same as rocker arms from pauter ( Porsche Rockers - Pauter) but this will be a lot better in titanium best regards |
Web Cam weld hardfaces used rockers.
So that is an option. |
Careful in your search for the "hardest/toughest" rockers or material available. I think there is something to be said for the cam being stronger than the rockers. If either of them had to be the "consumable" part in this equation, I think the rockers would be much easier to add into service inspection and replacement than camshafts. Just food for thought...
Thanks for all answers guys
It's a 914 ...
Keep in mind that unless you are revving over 8500 RPM that cast rockers are a failsafe for 911 engines. For example, if you overrev, you might bend a valve and maybe break a rocker if you overrev it badly enough. If you have forged rockers, if you overrev there is no weak link anymore, which can mean lots more damage ...
It's a 914 ...
Good point. OP - what springs are you using? I've seen some opinions expressed that some of the racing springs out there are really too stiff for our engines and cause unnecessary wear. I wonder if you are seeing that. Might be worth making sure you are solving the right problem here ... |
Yes I have also been thinking about my valvesprings might be something to consider again. They are from AASCO and are recommended, as I have been told, for my kind of enginebuild. I don't think they are that much stiffer than the original ones that they should be harmful for either original rockers or titanium retainers. Last edited by Litle brother; 05-21-2019 at 03:52 PM.. |
abit off center
Are only the intakes pitting?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
abit off center
exhaust get the most oil at least to the bushings: Pull a spring and measure the bind, and cam lift see if you have proper safety margin.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Please do not fit cast rockers in the event you over rev your engine the rocker becomes the "fuse". Fit the best rocker available for your application. Don't over rev your engine.
Spring pressures have to be calculated not assumed. The valve train part weights and the engine use are the most important factors here. All too often the spring pressures are far too high. Not just because of the elevated wear rate, but also the engine has to turn against this force. From the photo, it does not look like it was an oil starvation issue, but you should check the oil tubes. It does not appear there was any heat involved. It is hard to see exactly and the cam lobe may tell another story. Welded cam lobes if not done correctly will often cause issues as the lobe becomes the hardest part. Welding should only be done in the most special cases only. Unfortunately it is done often with unsuspecting results. All steels have inclusions when manufactured. Cast probably has the highest level of inclusions. Any inclusions under the surface will show up at sometime as the material above them will break down and the pits appear. Regrinding should be done with absolute care as the geometry can change. You can hard chrome the faces and grind back using the original radius point of origin. Care needs to be used when selecting who to do this work. We have had this done for years and have had zero failures. |
Kartoffelkopf
With absolutely no experience or technical knowledge on the subject of rockers and spring pressures, the only thing I would offer is that having spent some time with Brian Pauter when he popped in to see us on the Turbokraft stand at Rennsport Reunion, he seemed a genuinely lovely guy. Very approachable, straight up and easy to chat to. I know Chris works with him a lot as well, so if it were me going shopping, Brian/Chris would be my first phonecall.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Navin Johnson
Dopke used to refinish/make some nice rockers... doubt there are any available now.. he passed 11? years ago?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
