-   -   Best source for coated rod bearings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1018064-best-source-coated-rod-bearings.html)
sebastianroher 01-13-2019 07:13 PM
Hi everyone,
I'm using 2.7 Carrillo rods paired up to my 2.7 crank (std/std) and I want to know where I can source coated rod bearings?
Thanks,
Sebastian Roher
Walt Fricke 01-13-2019 08:25 PM
Calico sometimes has bearings already coated and in stock, and they will coat the ones you send if you don't need a faster turn around.
Mark Henry 01-14-2019 07:05 PM
LN Engineering sells coated bearings for 996, so I imagine they have them for aircooled as well.
sebastianroher 01-14-2019 08:48 PM
I'm going to go with Auto Associates in Canton, CT. $249 for calico coated Clevite rod bearings.
