WILSPEED's Avatar
High pitched exhaust note
Hey guys. A bit of a noob question. I have an SC with a NA 3.6 open exhaust which revs pretty fast but how the heck do some of these guys on the track have such high pitched exhaust notes, almost "F1" sounding???
For reference, one car in particular was a 911 track car with a NA 3.2 motor. I didn't get a chance to look underneath to check what it had specifically.
Is it just higher compression, exhaust piping, a combination?
Cannot find any info elsewhere. Any info appreciated,
Wil
Old 01-24-2019, 02:47 AM
exhaust
More than likely a 6 into 1 header system, a well developed engine has a different exhaust note vs. stock engines too
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-24-2019, 02:54 AM
It's a 914 ...
stownsen914's Avatar
What Mike said. I've noticed that some of the dual center exhaust outlets achieve a similar sound to the 6 into 1. I guess having the two outlets together in the center of the muffler is essentially like a single outlet.
I ran a 6 to 2 to 1 single outlet open exhaust for a while on my 914/6 track car. Sounded pretty wicked. Definitely a higher pitch shriek kinda sound.
Old 01-24-2019, 07:01 AM
WILSPEED's Avatar
I also have a 6 into 1 centered open exhaust definitely louder than stock but those other guys have a much higher pitched shrieking sound. Is it a high compression thing??
Old 01-24-2019, 11:33 AM
It's a 914 ...
Any other details you can share about the engine or exhaust on that car?
Old 01-24-2019, 01:22 PM
WILSPEED's Avatar
The one in particular I remember , the car was GT4 class in POC I think, 3.2 carrera motor. He was very tight lipped even though it was only a DE (what the heck?). I just saw he had open exhaust 6 into 1 but I have that too? He did mention he had a remapped ECU though.
Old 01-24-2019, 01:34 PM
WILSPEED's Avatar
It was a full blown track car, wide body, bi-wing , fiberglass bumpers and maybe quarters, lexan windows etc etc.
Old 01-24-2019, 01:36 PM
My friends call me Phish
here is my 2.7 and it gets really high pitched after 5k
https://www.instagram.com/p/BK3VEi7AJif/
Old 01-24-2019, 01:59 PM
WILSPEED's Avatar
Lol your laugh in the video! You have a great sounding car. Sounds wicked in the tunnel.
This other guyís car sounded more F1 like, almost like a 991 RSR from GTLM or GTE class pro racing.
Old 01-24-2019, 02:17 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
It seems like the small displacement engines that were really getting rapped out always sounded nicer than the 3.2 or 3.6 engines. The big engines seem to transmit those low tones and sound kind of tractor ish to my ears. My current exhaust on my 3.6 swapped Carrera is definitely a higher pitch... probably not F1 like youíre referencing, but itís my favorite try so far. Itís B&B headers going straight into a flomaster chambered muffler.
https://m.youtube.com/watch?v=ezbE24oswZI
Sorry the sound quality isnít stellar
Old 01-24-2019, 06:56 PM
valve timing/cam type, ignition timing and mixture also affect exhaust note. More so with an open muffler. My engine sounds very different from my friends similar spec engine.
80SC (ex California) 3.2SS
Old 01-24-2019, 11:46 PM
Chain fence eating turbo
High RPM allows for a higher pitch.
You might be hearing 8k+ RPM motors?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-25-2019, 10:02 AM
'76 911S 3.0's Avatar
Having a 6-1 with the primaries on the collector in sequential firing order should give you a high pitched sound like that, just listen to Tanner Foust's Passat drift taxi...this thing has 8-1 merge with the primaries in sequential firing order. Sounds like no other LS I've heard before
https://youtu.be/5Ot1qjHcruA?t=1096
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 01-25-2019, 11:34 AM
Go to church, listen, then look.
Seriously, I did.
I was invited by the curator of the Walt Disney Concert Hall in LA to listen and look.
Get it?????
Old 01-25-2019, 01:21 PM
Hi Will,
I remembered once looking (listening) for a new 6in1 exhaust and run into this....
It sounds not only on a RS high pitched ;-)
cheers,
Bart
https://www.youtube.com/watch?v=O6wuOUvDnzs
Old 01-26-2019, 12:23 PM
It's a 914 ...
Ran across a video showing what looks to be a vintage 911 race engine running a 6-2-1 exhaust. It's just revving in the garage, but to me it sounds distinctly different than the twin megaphones setup. Revs it at :35.
Old 01-27-2019, 08:58 AM
It's a 914 ...
Here's another one from a distance. Can't see the exhaust clearly, but it sure doesn't sound like megaphones.
Old 01-27-2019, 09:02 AM
WILSPEED's Avatar
Yes the sounds in those videos are what I was talking about!
Ok, sounds like a 6 in 1 open exhaust and high rpm is how itís done. Most 3.6ís Iíve seen donít run as ďhot.Ē Usually itís the 3.4 or 2.7 hot rod motors Iíve seen.
(Another newbie question) Can you and HOW do you get a 993 3.6 non-vario to rev 8k and sound like those guys in the video ?
Old 01-27-2019, 09:55 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
https://vimeo.com/14950324#t=1080s
Watch the 911 go by on the inside. It’s cstreit’s former racecar with a 3.3L non turbo engine with a 6-2-1 exhaust he cooked up with a resonator (think of the original 911 Euro premuffler shape) at the end of the system. It’s similar to a muffler that exits at the center of the car similar to what Scott posted
Here’s that same race from inside my car (nice camera position, right? ) at a different turn on the track. He comes by me on the inside after I wave
https://vimeo.com/15080050#t=1020s
Lastly, independent exhaust paths like megaphones isn’t necessarily going to get you that highpitch. Watch the start of that first video I posted. The dark blue 911 ahead of the camera car is mine (rookie noob and driving like it) and my exhaust setup sounds downright awful on decel/overrun. People behind me (well it wasn’t many people and they weren’t back there for long.....) often commented how loud it was and I think they were being nice. It sounded nasty back there. Inside the car it sounded fine
Here’s another listen to it from track side and you can also hear the difference in tone between mine and cstreit’s in this Gingerman video
https://www.youtube.com/watch?v=_a8pdgpaWec
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 01-27-2019, 11:46 AM
It's a 914 ...
Wilspeed - Getting a 3.6 (or any 911 motor) to safely rev to 8000 requires substantial internal mods and can be an expensive endeavor. You should be able to safely rev to 7000 though. If you are running open exhaust now, you probably have headers, right? I'd think that bolting on a single outlet open exhaust would achieve the sound you are seeking even if you don't rev quite as high - definitely a different exhaust note than the dual megaphones.
Scott
Old 01-28-2019, 03:53 AM
