-   -   37 years since last started (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1019131-37-years-since-last-started.html)
Vital Signs 01-24-2019 12:41 PM
66 911 with 80,000 original miles. The car has not been started since 1982. Whats the best course of action to get it running.
sugarwood 01-24-2019 01:57 PM
Search the tech forum and you'll find lots of threads.
Dmitry at Pelican Parts 01-24-2019 02:10 PM
Hello and welcome to the forum! Post some photos of the car for us to check out! As sugarwood said, lots and lots of threads with this info. I'm attaching a good starting place for you. Please let us know if you have any other questions.
http://forums.pelicanparts.com/porsche-911-technical-forum/650447-starting-911-has-been-sitting.html
kc911s 01-24-2019 02:18 PM
Did they drain the tank or is it full of gas?
Vital Signs 01-24-2019 03:35 PM
I drained the tank a few years ago and had it cleaned and coated the inside with oil. The fuel lines and carbs were never drained. I guessing that the lines and carbs will have to be rebuilt. Just wondering if starting the engine will damage it after sitting for so long.
VFR750 01-24-2019 04:40 PM
I would think a good thing to do is to assume the carbs, fuel filters, and fuel lines are compromised with evaporated fuel. Maybe even the fuel pump.
Certainly drain the oil and refill and change the filter
Pull the plugs and look inside with a borescope. Look for corrosion.
Change the transmission fluid too
Change plugs and distributor rotor and cap.
Pull the vavle covers and do a thourough inspection. Look for corrosion and anything that might make you think the rockers and valves are stuck.
Can you rotate the crankshaft via the nut on the fan? Does it turn relatively freely with the plugs out?
VFR750 01-24-2019 05:29 PM
Probably could remove the sump plate and look inside the engine.
Richey 02-18-2019 08:45 PM
I had a similar project , a '66 with 60,000 miles . I could not rotate the engine because of a pile of carbon between a piston and cylinder head . Also , the cylinders were rusty and needed some honing , and a connecting rod had a loose wrist pin bushing - a common problem on early engines - so the engine came apart . Of course it needed a valve job because of the worn copper valve guides . I believe you will have some of the same issues .
