So, back to the measuring technique - am I measuring in the correct spot on the piston? See the white dot on the photo - that's where i'm measuring - on the flat lip. https://lh3.googleusercontent.com/12...g=w424-h565-no |
You are correct. There is some discussion here. http://forums.pelicanparts.com/911-engine-rebuilding-forum/575057-deck-height.html
and https://rennlist.com/forums/964-forum/289949-3-8-rsr-deck-height.html |
FYI, you can make your rods longer. The small end bushing can be offset bored to make the rods slightly longer. Cost is listed as $250 from Ollies. Might get you were you need to be.
john |
The detonation that guys mention is at the periphery of the piston. Here's what a 98mm piston looked like in a 3.2L short stroke. See all the tiny little speckles around the left periphery? That's detonation. Eventually it gets covered up by carbon buildup. But it still doesn't stop the detonation.
http://forums.pelicanparts.com/uploa...1334036363.jpg Here's what caused the detonation- too much deck height. I thought the engine was a 3.0L, as that's what I was told when I bought the car. Engine was made of:
So my measured deck height in the cylinder was fat by over 1mm at a total of 2.4mm :rolleyes: This is a good thread I recall trading responses with Henry Supertec about the offset bored rods http://forums.pelicanparts.com/911-engine-rebuilding-forum/755709-upgrading-80-sc-w-88-3-2-p-cs.html Anyhow, the kicker here is that the long deck height also affects your compression ratio. If my pistons and combustion chambers actually measured up to the advertised 9.8:1 compression ratio, that loss of deck height would have resulted in a theoretical compression ratio of like 8.5:1 Knowing that the published compression ratio of the Mahle pistons is typically a bit optimistic, it was probably quite a bit less than 8.5! |
hha.. only joking.. or am I ???? |
Well... I managed to have another look at the deck height today.
Turns out that the deck height isn't as big as I first thought! When I sat down to think about why the gap was so big, I looked at the bottom of the venier calliper and noticed that the probe that slides in and out doesn't actually sit on the edge of the bottom of the caliper when they are closed (at zero)! So, when I was closing the calipers completely and zeroing them out - they had to slide that extra mm before it would even touch the piston... which is what led me to my big numbers. That will teach me to buy cheap measuring tools on ebay. So, with this new information, I got to measuring again. This time with no shim/gasket underneath I was getting 0.80 on one side of the piston and 0.90 on the other side - both measured at the location of the pin. Is it unusual that one side would be 0.10 higher than the other side? I wouldn't have thought it would be a big deal? possibly just how the cylinder was cast. They're not new pistons, only cleaned up and being re-used. The Victor Reinz shims that I have measure on a micrometer at 0.283 instead of the 0.25 they are sold as. These shims will take my deck height (only measured one cylinder today) to somewhere between 1.08/1.18. https://lh3.googleusercontent.com/nH...w1054-h1404-no I tried CC'ing the heads, but the plastic i purchased ended up being a little bit too flimsy - it was easy to cut though! :) How concerned do I need to be now about even measuring compression now that my deck height measurements are much more within spec? Thanks everybody for your help and advice so far. |
Sent from my Pixel 2 using Tapatalk |
| All times are GMT -8. The time now is 11:04 AM. |
