opening up manifolds for weber 46s
I have some weber 40 manifolds (corroded barrels)) that I would like to use with my Weber 46s. Is there a typical strategy? Top of the manifolds need to match bottom of the carbs, and taper to match the opening in the heads? I am going to assume that I can use a gasket as a template for both sides of the manifold. Is the typical manifold for Weber 46s a 42mm-38mm sizing? Am I crazy to think that I could "mill" the tops and bottoms of the manifolds to the correct size and then use my die grinder to massage/blend the taper in the throats? How do the "big boys" perform this?
TIA Speedo |
Puny Bird
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
machining manifolds
I like the PMO manifolds wihout question and have them on several engines. And they come in different flavors (sizes of exits). But to me, the earlier original manifolds look more "right" (a tall set of R manifold would really look "right"). And these 40mm manifolds need to be cleaned up anyway as they are a bit crusty. The way the barrels look currently...there would be more than the required amount of flow "turbulence"...just say'in. Still am curious about the machining procedure...machine both ends on a mill, and then die grind to taper? |
Puny Bird
I ported original manifolds, I also made machined aluminum and phenolic spacers.
I did most of the manifolds by hand with burrs and flap wheels on a die grinder. I used an aluminum spacer because the CIS injector notch on the SC head port can cause sealing issues with the original manifolds The original manifolds head flange doesn't have a whole lot of meat on them. The phenolic spacers to reduce carb heat.
Mark; how thick did you make the aluminum spacers ? I'd prefer to buy them, ID 34-38 mm if possible but so far no luck.
80SC (ex California) |
Puny Bird
I made them and the 1/4" phenolic spacers myself with a jig on the lathe. In the pic below shows what I did, but the order is wrong, the aluminum spacer should be on the bottom. ![]()
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 01-31-2019 at 11:00 AM.. |
