JoeMag's Avatar
Will a new oil ring seat in used cylinder?
Took my cylinders (3.8) off to add spacer due to head machining... One piston was a little wet on lower edge of piston (3.8 rsr's). pushed piston donw so that oil ring was exposed in windage cutout and I see oil between oil ring and #2 ring so I'm think'n oil ring might be failing (60hrs on race motor). If I install new oil ring, will it seat on cylinder?
Old 02-17-2019, 01:08 PM
Under the radar
Trackrash's Avatar
Yes, but you should make sure your cylinders are in spec and you should de-glaze the cylinder walls.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-17-2019, 02:22 PM
