rocker shaft anaerobic sealant?
Going through my engine and have read some threads on the pros and cons of RSR rocker shaft seals. Has anyone tried an anaerobic sealant?? Seems like it could be a pretty fool-proof solution if properly applied and cleaned...
Matt B '73 911E |
How are you going to apply it without smearing everywhere except where it should be?
andy |
I was thinking it would fill any crevices that could lead to leaks.
Matt B '73 911E |
I have used the green wicking Locktite on leaking shafts with good luck .
You apply it where you want it to be.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
