-   -   2.4 piston ring options (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1021592-2-4-piston-ring-options.html)
Mr Beau 02-20-2019 03:10 PM
I'm freshening a 2.4E that has Mahle pistons and cylinder. Everything measures great but needs fresh rings. What are my options? I'm not a big fan of the Mahle high-drag coil oil control ring... Some digging shows that JE has some iron moly that look like they would work nicely for $100 https://www.jepistons.com/Products/J640F4-3307.aspx
Mark Henry 02-21-2019 06:00 AM
For iron (and biral) cylinders I've had good luck with Deves rings.
The JE are Hastings which are also good, but confirm the price is for a set of 6...not a set of one.
