-   -   Alternative Cylinder Hold Down Nuts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1022129-alternative-cylinder-hold-down-nuts.html)
jamesjedi 02-26-2019 02:05 PM
Hi,
Is there an "off the shelf" alternative to buying the Stomski Cylinder Hold Down Nuts?
They are just M10 (I think?) for an SC motor.
Cheers and thanks!
'76 911S 3.0 02-26-2019 02:52 PM
I 3D printed some for myself, a lot less expensive that route.
tocobill 02-26-2019 03:06 PM
I made some out of aluminum on a lathe. Took a couple hours. If your stock it’s M10 1.5 if you have supertec they use M10 fine thread which is different so be aware.
Steam Driver 02-26-2019 03:27 PM
Cut PVC pipe spacers of appropriate length, use regular head nuts with a washer underneath; works great, REAL cheap!
jamesjedi 02-26-2019 04:42 PM
Thanks for the replies.
I’m guessing sockets would not work?
Sounds like there could be many options.
Thanks again.
'76 911S 3.0 02-26-2019 04:58 PM
You can also triple stack the barrel nuts for the ultimate free99 tool:
http://forums.pelicanparts.com/uploa...1551229110.jpg
Thread the first 2 all the way on and the third one cinches the group down.
jamesjedi 02-26-2019 06:19 PM
That one sounds very easy. I will most likely do it. Cheers and thanks!
tocobill 02-26-2019 06:30 PM
http://forums.pelicanparts.com/uploa...1551191253.JPG
jamesjedi 02-27-2019 05:37 AM
Thanks Bill. Sockets will work.
