micro encapsulated bolts
Hi
I have a 996 2003. Can the bolts 9921800501 (the black plastic oil separator on the crankshaft carrier) and 90007548601 (crankshaft chain guide) be reused if loctite 243 is applied to the male and female threads .....I have been told Loctite 243 is suitable but a friend said I should triple check !. thanks |
You might get more response on the 996/997/991 forum?
| All times are GMT -8. The time now is 04:55 AM. |
