-   -   Gains from going 3.0 to 3.2 but still on CIS? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1023205-gains-going-3-0-3-2-but-still-cis.html)
ebmbiker 03-10-2019 08:52 AM
Good day folks,
My '83 SC 3.0 engine [US spec] is being rebuilt at the moment and the guy doing the work says the barrels and pistons are ovalized and need replacing.
I could replace with Euro-spec standard 3.0 or opt for the Mahle 3.2 kit. I already have a backdated exhaust but will be sticking with CIS.
What gains can I expect from going with the 3.2 kit?
Cheers,
JB
Litle brother 03-10-2019 09:19 AM
Hi.
If you go with Mahle 98mm 10.3:1 cr p/c, 964 cams and euro spec fueldistributor togheter with your back dated exhaust you should be able to get 220-230ps.
It will be a good and snappy 3.2 short stroke engine with lots of torque and a super midrange.
ebmbiker 03-10-2019 09:51 AM
Originally Posted by Litle brother (Post 10384509)
Hi.
Cheers Litle brother, that sounds like some good gains.
Dpmulvan 03-18-2019 09:58 AM
3.2 cylinders and pistons are cheaper than 3.0 so an added bonus
flightlead404 03-18-2019 10:39 AM
you might consider going with frankencis to manage the mixture and ignition to get even more out of it.
Trackrash 03-18-2019 12:01 PM
Have you also considered going to the larger '78-'79 / Euro CIS?
Litle brother 03-18-2019 12:52 PM
Here's the p/c kit that will be the best choice:
https://www.fvd.net/no-en/10010303200/mahle-32-l-piston-and-cylinder-set-1031-98-mm-big-bore-for-911-30-l.html
Nux 03-18-2019 01:42 PM
Why not go for a 3.3 with p/c from LN Engineering?
Cheaper than FVD and 3% bigger bore = 3% more power (isch)
