Fresh out of mutton tallow - what to use instead?
Installing valve guides soon but forgot to order specific lube for the job..... what can I use that I'll have on hand? WD40? Nev-r-seize? Grease? Butter? Olive oil?
Or should I wait for the right stuff? I have done guides before but cannot honestly remember what I used for lube. Thanks in advance! Jon |
I fried some bacon just before I installed mine.
However, the Carrera manual specifies talc. |
Hey Gord, I remember you said that but I thought you were joking!!
Sheesh, I don't have any talc either. |
My garage smelled like bacon for a while. Yea, Sun and others have a "special" lubricant. I researched it and the main ingredient was tallow in the professional stuff.
I couldn't see springing for the professional stuff and I like bacon. :D Later I read in the Carrera repair manual they say use talc. I have never used talc, and it doesn't seem like a lube, but who knows. I would think KY or similar would work, since it is organic and would dissipate in heat. |
How about heating the head up?
- Rob |
Heat heads and freeze guides.
Sent from my SM-N960U using Tapatalk |
| All times are GMT -8. The time now is 03:16 PM. |
