-   -   Should I go near this case with a 10ft. pole? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1024497-should-i-go-near-case-10ft-pole.html)
Jonny042 03-24-2019 06:05 AM
This is a 7R mag case I'm very casually considering picking up for a future project.
It's basically a part of a basket case 1975 2.7 that's passed through a few owners for some reason.....
I'm told these are case savers, and obviously they've encroached enough on the spigots that the sealing surface is gone.
Run away?
http://forums.pelicanparts.com/uploa...1553432681.jpg
Daves911L 03-24-2019 06:48 AM
Yes, run away. I don't know that the sealing surface is that big a deal. Its just non-pressurized oil that can leak there. But the time-serts are not installed correctly (I'm assuming they have been expanded already). Getting them out to re-do correctly, without further damage to the case, is near impossible.
Catorce 03-24-2019 09:09 AM
I spent $7500 in machining with Walt Watson on a much nicer mag case than the one you are showing me, because I wanted my 914-6 to have a mag case motor. Lots of rehab work goes into a mag case to do it right, not sure that I would ever intentionally start a mag case build ever again!
Jonny042 03-24-2019 12:10 PM
Too bad nobody is making new mag cases :)
Next project maybe?
Catorce 03-24-2019 01:36 PM
Next project maybe?
The foundry can make mag cases for me, but I struggle to see the point. 25 pounds of weight savings can be found all over your average 911, there is no need to reduce the weight of the crankcase and simultaneously create a case that is weaker and inferior to an aluminum case.....
Flat6pac 03-24-2019 03:57 PM
Instead of spending money on twisted, pulled, deformed case, buy a 3.0 and be happy ever after.
Bruce
Jonny042 03-24-2019 04:48 PM
I was thinking (in the distant future) of a lightweight, hot rod, SWB. 25 pounds off the case of 2500 pound car is pretty high on the tree, I agree. But if you are trying to get sub 1800 pounds, 25 pounds would be worth a lot of trouble.....
But I am starting to have an appreciation for just how much trouble it might be. I am rebuilding a 3.2SS at the moment and all I have to do is clean the case. That's it. These mag cases look like a major PITA!
I can't help but think a mag repop might sell in decent numbers to vintage racers and hard-core Rgruppe types. I'm sure you've thought it over more than I have though!
deftom 03-25-2019 12:41 AM
Next project maybe?
Are you really sure about that??? link
Jonny042 03-25-2019 04:29 AM
The Pelican website is quite unreliable in that regard. The case is discontinued, if you check other online retailers.
deftom 03-25-2019 04:36 AM
Well, they recently reduced the price... so I guess they have it
I'm curious what it looks like! Is it made off agnesium??? etc etc
Catorce 03-25-2019 09:30 AM
They most likely have a few laying around in Germany but historically Porsche has been pretty lousy about stocking many of their cases, which is why I started making them. Also the tooling for these cases is either gone or unusable so there is a finite supply of the genuine article.
deftom 03-25-2019 12:57 PM
Making like really making??? Have you got picture??? And a price??
I'm curious :)
Catorce 03-25-2019 01:17 PM
^Which is why I have a link in my signature, please check it out, everything you want to know is on there.
cmcfaul 03-25-2019 02:05 PM
There is a copper gasket that goes over the mating surface. Could JB weld under it to help support the gasket. May leak a little but probably not. Had case savers on my 7r case with similar results to yours. Was fine. Problem with all magnesium cases is that they get brittle with heat cycles and age.
Chris
deftom 03-25-2019 02:22 PM
Very nice ! You just have to do a 2.7 case and you will have lost of customers around the world...
As lot's of people like me would be interested in something stronger but for a stock engine
Rosco_NZ 03-26-2019 08:06 PM
Please enlighten me .. what’s wrong with the Case Saver installation in these cases ... about to embark on a similar project .. seeking good info
cmcfaul 03-27-2019 04:45 AM
Nothing wrong with them. Nice upgrade. These seem to not have been installed correctly.
Chris
Clint Lando 03-27-2019 06:56 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/365898-minimum-meat-spigots-14x2-case-savers.html
Trakrat 03-27-2019 08:48 AM
I believe it's how close the hole goes right up against the edge of where the pistons would be. The hole on the top right of the pic is VERY close to the edge. It almost looks like some of the inner cylinder wall is missing.
When putting the heads back on, you aren't going to be able to seal it up very good an most likely oil will leak around that hole.
While the inserts themselves look fine... it's how close to the edge the holes are.
cmcfaul 03-27-2019 10:13 AM
The case savers are not inserted all the way. A copper gasket goes over edges where the holes were drilled. Should be fine but not ideal.
Chris
mepstein 03-28-2019 09:43 AM
Bruce
I agree. Even after you spend $2500+++ on machining the mag case, mag still degrades quickly. Cracks, crumbles, warps, ect. There's many good reasons Porsche went back to aluminum on the 3.0 and larger, turbo, ect.
Rosco_NZ 03-29-2019 05:04 PM
Looks to me like the head stud holes and therefore the inserts have not been placed in the right spots. Therefore the cylinders will not locate or seal correctly. I think 2.4 to 2.7 is a common conversion if done correctly but this like an amateur hack. It could be corrected by inserting and re-drilling in correct locations but considerable work.
Daves911L 04-06-2019 11:59 AM
Looking at the pictures, I would guess that whoever installed these simply bought the inserts (cheap), and did the install with generic cutting tools (drills/taps). The time-serts kit includes the correct sized drill, and an adjustable counterbore tool. The correct counterbore does cut through the edge of the cylinder spigot, but only slightly, and leaves a recessed surface in the case the precise diameter/depth to accept the top flange of the insert. These are ugly because somebody just used a big drill bit to clearance for the flange, and chewed much farther into the cylinder spigot than necessary. And then they didn't even get the inserts screwed in flush with the case surface. The boring/tapping should be done on a drill press, or ideally, a mill. These have the look of having been done with a hand drill. With everything else done wrong, its fair to assume these were not "locked" in place with a roll tap (also included in the kit).
john walker's workshop 04-08-2019 07:43 PM
Timeserts are more apt to pull out than case savers.
