-   -   starting engine after top end over haul! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/102587-starting-engine-after-top-end-over-haul.html)
crashmy911 03-17-2003 06:11 PM
How and what should I do. Engine has new rings, valve grind, and new cam profile. Steps to follow? Thanks every one.
Doug Zielke 03-17-2003 07:45 PM
From the "Big Bird" (and his new and excellent book) ......
http://forums.pelicanparts.com/911-engine-rebuilding-forum/102532-engine-break.html#post732581
cstreit 03-21-2003 08:21 AM
Make sure you run the motor for 20 minutes at 2000-2200 RPM when you first start it so the new cams and rockers break in with proper oil pressure. Don't let it idle for long.
snowman 03-21-2003 09:21 PM
And change the oil plus filterafter the first 1/2 hour. A whole lot of junk comes out after a rebuild.
