-   -   Thoughts On This Cam Image? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1026435-thoughts-cam-image.html)
jamesjedi 04-11-2019 08:38 AM
Hi,
I was hoping to hear some thoughts on this cam picture. It is a regrind, but I am not sure what to make of the lobe markings? Any thoughts would be appreciated.
James
http://forums.pelicanparts.com/uploa...1554997090.JPG
silverc4s 04-11-2019 09:20 AM
Lack Of ZDDP??
silverc4s 04-11-2019 09:21 AM
Valve clearance too tight?
silverc4s 04-11-2019 09:22 AM
Poor hardening following regrind?
silverc4s 04-11-2019 09:23 AM
General lack of oil in valve train area.
VFR750 04-11-2019 04:21 PM
The oil film broke down.
What do the rockers and rocker shaft surfaces look like? Post some pictures. Preferably the hardware from those two lobes.
That info is needed for a better answer.
jamesjedi 04-11-2019 05:05 PM
Thanks for the replies.
I do not have any more pictures. The cam is for sale.
Is the repair the same cost as a regrind?
Dpmulvan 04-12-2019 06:06 AM
Run away as fast as you can
jamesjedi 04-12-2019 06:52 AM
OK. Thanks, damage is more than I thought.
