-   -   Zenith carbs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1026441-zenith-carbs.html)
911Tfan 04-11-2019 10:20 AM
Zenith carbs
Hi,
Does anyone know a good zenith carb rebuilder or shop that sells rebuilt zenith carbs?
Or rebuilt weber carbs?
VFR750 04-11-2019 04:27 PM
I don’t know who currently rebuild them.
There are rebuild gasket kits and exploded views of the insides of a zenith to see what all the parts inside look like.
. I rebuilt mine originally.
I did a custom upgrade a while back, but it is not needed.
chiroracer 04-12-2019 04:31 PM
performance oriented.
VFR750 04-12-2019 04:53 PM
Paul (performance oriented) did a custom transition port modification to my zeniths.
He and I chat occasionally. He’s one of the good guys.
If you check his website you will see he is not currently taking on new work.
Alfa1750 on eBay sells a lot of rebuild parts for Zenith TIN. I use him all the time. Since getting new parts is half the battle, a competent shop could do the work, and use new parts as needed from alfa1750.
Parts come from Italy. Generally in one week.
So that is an option to a specialist.
Hi_Fi_Guy 04-18-2019 10:07 PM
Don’t be afraid to rebuild them yourself. Tons of good info on this site.
