matching pistons to Cylinders for 87 911
I have a engine out of a 87 911 that im rebuilding. car sat for a while and had water in the cylinders damaging the pistons. the cylinders are MAHLE nikasil cylinders. I have a good set of SK pistons from a set of alusil cylinders that measure out perfect. Will these pistons work with the nikasil cylinders? thanks in advance!
There should be complete sets of matching pistons, cheap, because people open the cylinders and pistons are left over.
Be sure you match sizes Bruce |
I have a nice set of Mahle 3.2 Euro pistons that would work for you. PM me if you are interested.
pistons
Alusil pistons will not work with Nikasil cylinders.........
however, I have a nice set of 3.2 Nikasil pistons, just removed from a very nice running, backdate project..... $150 + shipping for the set. http://forums.pelicanparts.com/uploa...1555342953.JPG http://forums.pelicanparts.com/uploa...1555342953.JPG http://forums.pelicanparts.com/uploa...1555342953.JPG regrds, al |
I wouldn’t be willing to do the experiment, however, I don’t see why Alusil pistons wouldn’t work. They have a ferrous coating, but that is softer than the Nicasil coating on the cylinders. The reverse is true though. Nicasil pistons cannot be used with Alusil cylinders.
-Andy |
I believe it is possible to used the Alusil pistons in Nikasil cylinders as long as the Nikasil rings are used rather than the Alusil rings.
For $150, Al's pistons are the way to go. That price is a gift.
I have this set of 3.2 Euro pistons. I will PM you the details.
http://forums.pelicanparts.com/uploa...1555438756.jpg http://forums.pelicanparts.com/uploa...1555438756.jpg http://forums.pelicanparts.com/uploa...1555438756.jpg |
My 3.0 SC engine has been doing just that for the last 5 or so years. |
regards, al |
http://forums.pelicanparts.com/uploa...1555514347.JPG |
All 3.2, weather 9.5 or 10.3 have the same casting numbers
The height of the high side is the difference by several mm. Bruce |
Here is how to tell the difference between them.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/321712-help-identifying-3-2-carrera-pistons.html |
| All times are GMT -8. The time now is 02:24 PM. |
