Oil breather gasket installation
1989 911 3.2 Carrera engine rebuild.
Wayne's book says install breather cover gasket dry.
Ultimate sealant thread says use loctite 574.
Do I use the 574 on both sides of gasket? If only 1 side which one?
I did my triangle of death several years ago and installed dry with no problems but going with current conventional wisdom.
Thx!
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 05-31-2019, 12:29 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
These things are known to warp really badly & source of leaks ... sand flat on a machined block first.
Old 05-31-2019, 12:32 PM
I should also mention I have the Wrightwood racing gasket set so the breather gasket is the grey/silver one.
Regarding sanding, the cover is extremely smooth and flat. The block is assembled so doesn't seem prudent to sand anwhere near openings.
Thanks!
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 05-31-2019, 02:08 PM
I ended up putting a thin layer of 574 on both sides of gasket and buttoned things up.
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 05-31-2019, 04:24 PM
Puny Bird
Mark Henry's Avatar
One sealant not on the list is Loctite SI 5900, I rub a little bit into paper gaskets and use it under nuts, etc, never leaks.
Yes it's an RTV, get over it, it's not the old RTV. Did you know that threebond/yamabond is RTV?
Loctite SI 5900 is porsche spec on 996/997 engines.
Not affected by fuel and oil, when used correctly it's good stuff.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-01-2019, 05:17 PM
Jeff Alton's Avatar
5900 is good stuff. We use it on every M96/97 motor we build as well as various other jobs around the shop. It is not a product we have used in addition to a gasket, but others like Mark may have had success doing so.
However, the breather cover should not need any sealant. If you choose to add a sealant, many have had great success with a thin coating of Loctite 574, just enough to get it wet...
Cheers
www.turn3autosport.com
Old 06-01-2019, 08:12 PM
Puny Bird
Mark Henry's Avatar
As I said I just rub a bit of 5900 into the paper gasket, no excess what so ever is an important note.
On removal the old gasket peels off whole with little clean up.
I also discovered 5900 from building M96/97 engines, at first I was taken aback that it was RTV, but quickly realized it was a superior product. I've disassembled lots of M96/97 engines that pervious wrenches had used way too much product, not good but the squeeze out never goes anywhere.
I tried this trick with threebond, sealed well, but removing it just ripped the gasket in half and was a total PITA to clean up, so I don't recommend trying this with the threebond.
Old 06-02-2019, 06:34 AM
