Engine stall on throttle lift
link no
Old 04-23-2019, 05:25 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
You will need to post what year, engine and fuel system in your car so people can begin to help you out. And you should post your question in the 911 Tech section, hopefully your engine is OK and not in need of a rebuild.
1986 Targa Guards Red
2012 Cayman S
Old 04-24-2019, 02:44 AM
Jonny042's Avatar
Probably a 3.2 that needs the base idle raised?
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The Rot Rod! AX beater
Old 04-27-2019, 04:26 AM
