-   -   Least to most expensive 911 engine (air/oil cooled) to rebuild and why? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1029287-least-most-expensive-911-engine-air-oil-cooled-rebuild-why.html)
tdskip 05-17-2019 01:50 PM
Originally Posted by lvporschepilot (Post 10460674)
Not a one on the 3 I've done so far. Regardless, I still removed all the studs and had a machine shop installed case savers ($500). Used the original steel head studs on all of them. 1 is a very abused 2.8 track engine too AND that engine has cast iron (shock, horror) liners. Runs absolutely fantastic. I recently swapped that one to a DC80 cam.
That is encouraging to hear
