Anyone have a spare 98mm compression ring for JE 9.5:1 pistons?
In the process of rebuilding my 3.2->3.4 motor and managed to screw up one of the top compression rings when opening up the end gap. I re-checked all the others and they are fine, so I though I would see if anyone had a spare ring that would save me from having to purchase a new set for only one ring. I'm using the rings that came with the pistons that I purchased from EBS.
I can be reached text 408 921-5568 or email william_dunham@yahoo.com
Thanks!
Bill
Old 05-24-2019, 07:57 AM
I have a partial set for 3.4 Mahle rings. What is your thickness?
Bruce
Old 05-24-2019, 08:35 AM
Thanks Bruce! I will need to check the thickness tonight when I get home.
Bill
Old 05-24-2019, 09:59 AM
The rings I have are .038" thick (.97mm) and .145: (3.56mm) in width. The look like stainless steel on the surface, in contrast to the 2nd oil ring which is charcoal in color.
Hopefully that's what you have :-)
Bill
Old 05-24-2019, 06:11 PM
Looks like Bruce's spare isn't a match, so still in need of one with the above dimensions.
Bill
Old 05-25-2019, 06:40 AM
