16 Fin Mahle, what are these cylinders?
I purchased a 2.2 engine reportedly built to S spec by Jerry Woods racing.
The cylinders have 16 fins, have MAHLE cast into them and I have been unable to find any information on this as everything I find says they should have 10 or 11 fins. They are not magnetic, so assume aluminum. Does anyone know what I have here? ![]() Thanks, David
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra Last edited by David Borden; 05-19-2019 at 04:44 PM.. |
Biral?
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
Under the radar
Yep, they appear to be birals. Which is what the S would have had.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-20-2019 at 08:52 AM.. |
Thanks... Appears that they are indeed Biral.
What barrels did the 1972 911T, E and S come with from the factory? Should I be concerned or are they an acceptable option for an occasionally tracked car? Would Jerry Woods have used these in a "track day" type build approx 15 years ago?
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra |
Under the radar
The cylinders were the same up to and including the '72s. Ts had cast iron cylinders and the Es and Ss had the Birals. Only difference from '70 to '72 were the pistons and cranks.
Nicasils first came out with the 2,7s. Those cylinders should be fine on the track.
Thanks Gordon, I appreciate it!
