-   -   G50 3.2 Head Studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1030852-g50-3-2-head-studs.html)
Dauner 05-29-2019 03:51 PM
G50 3.2 Head Studs
Car is 1989 911 3.2 . Full engine rebuild. Removed my dilivar head studs for replacement as a matter of course. Pelican has Turbo head studs that are $10 that according to the search engine fit my car. Going thru the site menus also shows Porsche head studs for $20. Other suppliers show options for OEM studs that are again in the $10 range. What is my lowest cost option that is of acceptable quality and capability. Building 3.4 for street daily driver.
Thanks,
Mark
Flat6pac 05-29-2019 04:34 PM
Standard steel studs are fine for the street and fun, just be sure you torque to Carrera specs.
Bruce
cmcfaul 05-30-2019 01:56 PM
Did not know the 89 Carrera still used Dilivar. Add that to the top end rebuild coming up.
Chris
Flat6pac 05-30-2019 03:00 PM
The C2 has 24 dilivars
Bruce
Dauner 05-31-2019 12:25 PM
Will the turbo steel studs that are 10 dollars cheaper work on my engine?
Thx
Flat6pac 05-31-2019 05:44 PM
Most that I have purchased lately are $17-20 each
Bruce
