-   -   Lone nut camchain port removal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1031047-lone-nut-camchain-port-removal.html)
Catorce 06-07-2019 02:38 PM
^ Can't wait, thanks as always Neil!
Henry Schmidt 06-09-2019 06:38 AM
Originally Posted by Neil Harvey (Post 10483263)
....edit...
You know something, you can fix mag cases but you can't fix stupid.
Originally Posted by jess p (Post 10481278)
Where I come from that’s how we spell it. You are exactly right, only fools send those mag cases to the machine shop. That’s why I’m not doing it.
Neal is right!!!
As someone who has built hundreds of these engines over the last 40 years, I find your assertion that "proper machine work" is some kind of scam to be offensive.
You came to this forum asking advice and dump a load of shyt on those who try to help you.
Every single 2.7 mag case with mileage will have line bore issues. The pertinent question is "how much"?
I always get a kick out of newbies that have it all figured out....
Good luck to you on your journey to "cheap it out...."
There are reasonable compromises but willful blindness is not one of them.
Jeff Alton 06-09-2019 10:17 PM
Originally Posted by Henry Schmidt (Post 10485591)
Neal is right!!!
Henry and I have not always seen eye to eye. But I have a ton of respect for his experience and knowledge. He is 100% correct in what he is saying.
Best of luck in your "rebuild"...
Cheers
Dpmulvan 06-10-2019 05:27 AM
Yeh ok your going to line bore a mag case with a Bridgeport Mill?? That comment alone shows your an idiot. Maybe try a dremel or hole saw.
jess p 06-19-2019 08:12 AM
Neal is right!!!
As Neal said, “ how did this thread for a stubborn nut which wasn’t a nut turn into this. I didn’t ask you for your 2-cents on anything. I couldn’t care less about your advice.:eek:
Henry Schmidt 06-19-2019 11:23 AM
It was not my intention to "give you advice".
It was my intention to pull down your pants and paddle your arrogant ass...
I guess I hurt your feelings as well......waaaaaa!
jess p 06-19-2019 03:57 PM
Who is that calling?
That’s your mom, she wants you to go to your room. :D
Bigtoe32067 06-21-2019 01:24 AM
Haha. DpMulvan my Bridgeport mill comment was facetious, a joke. I wouldn't even know how to set one up and it was in no way meant to mimimize the effort some people put into machining our engines for us and if I offended anyone it was not my intention.
It was the equivalent of saying if I needed $7k worth of machine work on my 7R I would throw out the window. Maybe I should've said that in the first place. I actually just got through watching an hour of the School of Automotive Machinists machining a block and heads and am fascinated with the amount of work and measurement and setting up the equipment required. And am thoroughly impressed with the select few magicians who can do the proper machining to make our engines better than when they were new.
So my apologies again to anyone I offended especially those with machine shops since I'm about to tear down my 7R for rebuild and will need the services of a good machine shop who knows these cases well.
P.s. The dremel idea might just work.
Tony
jess p 06-22-2019 07:30 PM
Tony
I don’t think you offended anyone. At this point you have to question a poster on this blog who is in to pulling down other men’s pants!:eek::eek::eek:
boyt911sc 06-23-2019 01:31 AM
Arrogance will take you no where.......
Originally Posted by jess p (Post 10477268)
Hello everyone
I’m rebuilding my 74 2.7 and I’m having difficulty separating the cases due to that lone nut in the camchain port left side cyl 1-2-3. The nut I suppose is just stuck to the stud and the whole thing just turns and turns, I’m getting nowhere. Any ideas? :eek:
Thanks in advance
65 912
66 912
67 912
70 914
71 914
74 911
81 911SC
Jess,
You came to this forum seeking advice for your disassembly problem because you simply could not figure how to fix it. That was a good decision you made. Unfortunately your ignorance and arrogance have dominated your emotion. And started acting like a fool. This was the exact word you described some people you don’t even know.
Your reaction to comments and suggestions was some what illogical and uncalled for. It is unfortunate you have been referred as STUPID but you deserve it. Your posts are simply giving a clear picture of your mental ability to comprehend your disillusionment.
You got a serious attitude problem. Take a break and just lick your wound. And just focus on your engine rebuild to keep you occupied. Wish you luck.
Tony
jess p 06-24-2019 04:14 PM
Originally Posted by boyt911sc (Post 10500600)
Jess,
Tony
Whatever dudeSmileWavy
jess p 06-24-2019 04:49 PM
Jess,
Tony
Tony
Here, I want you to take this free phone ☎️ pass. Call your mommie and tell her you put your big boy pants on and spoke up to that big bad man on pelican. She will be soo proud of you.:eek:
mike fitz 06-24-2019 08:04 PM
The end
