-   -   Removing engine tin before drop (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1033081-removing-engine-tin-before-drop.html)
givory 06-25-2019 06:02 AM
0n my ‘89 3.2 I’m about to attempt my first drop for this car, which I plan to do (with gearbox) between the ramps of my 4 post lift on to a hydraulic lift table. I understand I will need to remove the engine tin and exhaust to make it fit between the ramps. But since every drop I see seems to include tin, I’m wondering how difficult it is to remove tin before the drop?
Thanks for any guidance,
Gavin
Trackrash 06-25-2019 09:35 AM
It is MUCH easier to remove the tin after the motor is out.
Replacing the tin with the motor in is a real PIA.
I'm sure those who have dropped motors with a 4 post lift will chime in.
Flat6pac 06-25-2019 09:36 AM
Just some screws except the left front with flywheel sensors and 2 bolts coming down
Basically just busy work and a time consumer.
Bruce
givory 06-25-2019 09:44 AM
Ok thanks- not preferable, but doable ... is what I hear. I will give it a try.
