-   -   Timing Chain Replacement (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1035033-timing-chain-replacement.html)
jamesjedi 07-18-2019 08:34 AM
I have read that the sprockets should replaced when replacing the chain. Is this always the case? If the sprockets look good - why not just do the chain?
Looking forward to seeing the replies. Thanks
Bigtoe32067 07-18-2019 09:05 AM
If the sprockets look good then I'd just replace the chain.
Tony
jamesjedi 07-18-2019 09:28 AM
Thanks for the reply. My engine does not appear to be high mileage, sprockets look ok.
TravisSolomon 07-21-2019 10:17 PM
One can also lubricate it if it is get rusted which make it run smoothly.
