-   -   IMS discoloring okay? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1035363-ims-discoloring-okay.html)
mike sampsel 07-22-2019 11:16 AM
Pictured is my shaft with the discoloring. Should I do anything about it (other than a happy dance for nearing putting it in the case).http://forums.pelicanparts.com/uploa...1563817839.jpg
bpu699 07-22-2019 12:02 PM
What discoloration? By the oil galley?
I just took some 1500 grit wet/dry paper, wrapped around the journal, took a shoe lace and VERY gently rotated it several times to polish it...
Probably achieved nothing, but made me feel like I did "something" to improve it...
mike sampsel 07-22-2019 12:06 PM
Right, bpu699 the circle by the oil inlet hole.
I’m good at having fun probably achieving nothing!
Flat6pac 07-22-2019 12:09 PM
The bearing you removed has an oil galley there so there is no contact to the shaft.
Bruce
eastbay 07-23-2019 11:06 AM
Pull the snap ring and plug out of it and clean out the gunk (if you haven't yet)
