Valve timing 20/21 cams
So I am a newbie at valve timing. Are 20/21 cams more difficult to set the timing than a stock cam?
no, process is exactly the same.
john |
The process is the same, but the measurement value is different. Ensure you have the correct lift data at TDC overlap for those cams.
| All times are GMT -8. The time now is 11:14 PM. |
