-   -   Quick and easy DIY P221 and P222 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1036412-quick-easy-diy-p221-p222.html)
Jonny042 08-03-2019 05:18 AM
Just putting this here for people who might search for this in the future. I bent up my own out of some 1/8" welding rod. Took minutes, and cost pennies!
http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered-34.html#post10544093
On my SC motor the #3 rod was happy enough to rest against the oil pump so no 222 required there.
http://forums.pelicanparts.com/uploa...1564834314.jpg
Since I didn't have a helper (or a third hand) I used a bit of wooden dowel as a lifting handle for the #1 and #2 rods.
http://forums.pelicanparts.com/uploa...1564834570.jpg
piscator 08-03-2019 04:00 PM
Neat! Thanks for posting this!
jjeffries 08-03-2019 04:24 PM
I used bent coat hangers; not pretty but got me where I needed to be. Johnny 042's are nicer!
Inkblot 08-03-2019 05:31 PM
Filed under “Wished I’d thought of that” :)
Trakrat 08-07-2019 07:29 AM
I hope the picture is just a 'poser' shot of your crank in the case for us to see.
I don't see any assembly lube or a nose bearing installed.
Harpo 08-07-2019 01:17 PM
Could you please post some measurements of p221 & p222
mikedsilva 08-08-2019 04:57 AM
Clever bugger!
Jonny042 08-09-2019 05:54 AM
Correct!!! Actually there is assembly paste on the bearing shells that you can't see.
Jonny042 08-09-2019 05:57 AM
There are some dimensioned pics available if you search google images of the actual tools.
In my case they were custom fit. The P221 (long one) is as long as I could make it from a 36" piece of welding rod :)
