-   -   Why shave piston skirts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1037218-why-shave-piston-skirts.html)
speedo 08-12-2019 10:02 AM
Looking over a nice set of 2.2 S P and Cs I was going to use to build up a 2.2 S engine, and I noticed the skirts have been shaved?
Why would a builder do this? Weight savings? Pistons and cylinders look to be in very good shape, and measure in spec. :confused:
http://forums.pelicanparts.com/uploa...1565628984.JPG
faapgar 08-12-2019 10:06 AM
shorten skirts
I used to use 2.2S Pistons on a 70.4 crank.I believe I trimmed 9 or 7mm off the bottom for clearance purposesFred
MBruns 08-12-2019 10:49 AM
Yup, that's why
Mike Bruns
speedo 08-12-2019 12:00 PM
pistons
Thanks guys! Coincidentally...that is the plan. To stroke the 2.2 T engine I have and build a 2.4 using the 2.2 P and Cs.
Speedo
