Targa_PB_78_SC
mike sampsel's Avatar
Any substitute Cir-clips for JE pistons?
Install of JE provided cir-clips in JE piston bore for rod pin is a real challenge.
The stomski tool helps but it’s still a struggle to seat the clips.
As such I wonder if some slightly less stout clips might be available?
And would I want to use them with my JE pistons.
Some whining:
And here I though after I got all my pistons ringed and in my cylinders it would be smooth sailing. Not any easier with a bumb dominant thumb installing these clips
Old 08-15-2019, 12:28 PM
Targa_PB_78_SC
Well sometimes a whiner finds an acorn!
Went to stemski video on how to use his tool, followed method.
Holding it at an angle to the piston rather than flush and I had circlip inserted in its groove in about five minutes. Right technique made all the difference
Old 08-15-2019, 03:21 PM
(man/dude)
Jonny042's Avatar
You'll be amused at the lengths I went to, to get the Stomski tool to work....... had I watched the video I would have saved a lot of trouble. The circlip nonsense starts on page 34.
Project Heavy Metal - an all steel classic, remastered
I dislocated my dominant (right) thumb 6 or 7 weeks ago. I feel your pain, literally.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 08-15-2019, 04:23 PM
finally a good tool
After 2,500 plus motors he comes out with a great tool.Never had been a problem until the JE Clips.
Old 08-15-2019, 04:52 PM
Jeff Alton's Avatar
Years ago I stuck a modified screw driver literally almost through my had with these bastard JE clips... Thread is here somewhere. Then I bought the Stomski tools, we use them on all aircooled builds. Porsche has a similar, thought longer tool, for the water cooled motors. Makes things much easier....
Cheers
www.turn3autosport.com
Old 08-15-2019, 09:05 PM
Targa_PB_78_SC
@ Johny042 interesting documentation on the circlips from JE. I see you trimmed yours a bit.
I’ve installed three of my left hand circlips per my photo. Funny how one took thirty tries to get in and another went in on the first try. Number 3 piston went first try, guessing because it was easiest to get all at the proper angle. I talked to a pro at Pclub breakfast this morning he told me he just uses a screwdriver (properly shaped) but they aren’t JE (sadist designed) circlips either.
Lucky a wise mentor told me to leave off my bottom studs for now. It makes things easier. I might try trimming my clips if I get too far behind.
Old 08-17-2019, 01:37 PM
