-   -   Circlip drop recovery method for dummies (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1037713-circlip-drop-recovery-method-dummies.html)
mike sampsel 08-18-2019 11:26 AM
Well I had my cylinders holes covered (not good enough). Alas I dropped a circlip into the engine. Looked with bore scope and tried magnet to no success. Crank turned fine.
Then I turned engine so the side without cylinders and pistons faced the earth. Picked up the engine and stand a few inches (just one set of wheels, I’m weak) and dropped them. After about three drops I noticed a circlip on the floor. :D
Will get my last circlip on tomorrow, celebrating this event!
Jeff Alton 08-18-2019 10:19 PM
You aren't the first to drop one in the motor, nor will you be the last! Good to hear you got it out relatively easily!
Cheers
mike sampsel 08-19-2019 02:29 PM
Cheers
Thanks, Good to know I’m not alone.
