-   -   911t Rebuild 1970 2.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1037971-911t-rebuild-1970-2-2-a.html)
dpetteng 08-21-2019 12:28 PM
So, in my other thread I was looking for advice on why my engine wasn't running right. Now I know - one of my valve seats is screwed after taking the engine apart.
So, this is a 1970t on zenith carbs. While the engine is apart, everyone talks about upgrading to "e" cams. Does that make sense while I have the engine apart? If so, what would be the part number for "e"cams and where could I buy them?
If I went to "e" cams, would I need to do anything to my zeniths?
Trackrash 08-23-2019 01:19 PM
T cams can be reground to E specs. However, I don't know if E cams will not collide with your stock T pistons.
Some adjustments to your carbs would be in order.
