VICTOR REINZ Porsche 911 Engine Gasket Set?
Hoping to get some guidance.
VICTOR REINZ Porsche 911 Engine Gasket Set I have purchased it already. It has not been getting good reviews. What parts of the kit can I reliably use? What to replace? I see that teh Wrightwood kit has better reviews. Thanks for any assistance. |
The biggest problem I have read here is the oil pump squared O-rings. Some kits had them too short, so there wasn't a good enough seal between the cases and oil pump causing no oil pressure.
That would be an issue. I really dont want to spend the money on another gasket kit. I may have to.
I use the Wrightwood Racing on the low end, Victor-Reinz on the top end.
What was the justification to use the VR on the top end?
Others may disagree. |
CE rings in the Victor Reinz kit are suspect.
Sizing is all over the place so fit is hit or miss. The last ones I ordered (just trying to keep moving forward on a project) were so bad I sent them back and put the project on hold until I got some from Wrightwood. I've seen oil return tube o-rings after install before the engine was ever started. Gasket thickness is also inconsistent. |
Thanks Henry. Well - I will try to return them, but most likely past the return date.
Thanks for all the replies. |
It's so frustrating to me that there are so many questionable parts being sold for these cars.
I am lucky that I will be able to return mine. That said, they may be very good as I have not opened the package.
However, I am going to go with what the professional builders are recommending. I will be buying the Wrightwood Racing sets. |
| All times are GMT -8. The time now is 01:05 PM. |
