Reviving a 20 year dormant 3.2
I have a 3.2 from a 1988 From a theft recovery car that has not been on the road since around 1997. When parked it had 65,000 miles on it. Besides the basics, what should I do to it before putting it back into service?
Would it make sense to take it apart for inspection? I hear they are hard on valve guides, should I send them out for a rebuild even though the mileage is low? Thanks in advance for your input |
If you’re going to take it apart, get the heads done and the studs.
Problems will be in the fuel system. If it turns over, go with it. Fresh injectors would be first call. Bruce |
I know studs are an issue on a 3.0, I replace mine during my last rebuild but is it an issue with the 3.2 too?
Injectors will be sent out for service. |
I've been learning a lot watching car restoration shows on Netflix.. apparently when you get a really old car that has not been run in 30 years or more, all you do is give it gas, turn the key, and rev the bejesus out of it! If it runs, you high five each other on a job well done!
Sorry for the sarcasm... I stumbled across a show called Rust Bros ... Canadian.. one of those shows that was so tragic I couldn't NOT watch it... Back to your engine.. I just rebuilt a 3.2 which had 3 broken dilavar studs.. they will break. |
i would see if it starts. fresh oil obviously, filters and gas. Build oil pressure on the starter, flush fuel lines from tank through rails and back to tank, then check for spark and fuel through injectors then see if it runs
I can't figure out how to post a link, but I asked a similar question about resurrecting a CIS after a 6 year sleep and Henry responded with a couple of posts from Grady that were extensive and thorough.
I have changed the oil and filter, will fogg the cylinders with oil, check the valve adjustment and cyl head torque, drop the engine to facilitate checking the cis FD plunger, pull the injectors, (including the cold start) to flush the fd, lines and injectors, without dumping a lot of gas into the cold start manifold and cylinders, check and lube the distributor, replace fuel lines, filter,tank, (perforated), pump, (questionable and not compatible with front mount and new lines from Len Cummings), THEN, spin the engine without plugs to get the oil moving, install new plugs, battery and premium gas. Turn the key and seei if it will run. Grady has a lot to say about the importance of breaking in the engine again to avoid catastrophe. Brake calipers, fluid, lines, front wheel bearings, possibly CVs, tranny gear oil, all likely need attention too. Good luck, chris |
The motor is out of the car. I will have the injectors done but I guess my questions are:
For a good long term engine should the head studs be replaced? Do you think after sitting that long will it leak like a sieve? Should I take it apart and reseal it? Besides the injectors themselves, do the injector system need any service? |
Unlike CIS the only fuel is in the rails and connecting hoses
Bruce |
I think head studs should be a low priority now . Follow above guidelines and inspect the timing chain tensioners .
Headstuds are an issue for 3.2s also. But no need to tear it down now unless there is more issues.
I wouldn't touch the low end, it'll be prisine at that low of miles. Maybe do the valve guides as others have stated and put in new studs like 993TT.
If it's going to be a screamer, maybe new ARP rodbolts? |
Valve guides aren't as much of a problem as the springs no longer being within tolerance. The guides are only as good as the supporting equipment around them. I'd say, take the chain box covers off and inspect the chains and chain guides. Pull the valve covers off and manually inspect inside. Having someone turn the engine while you look at each intake and exhaust valve move up and down. Like other have said... your fuel system will be a concern. It all depends on what environment the car was left sitting in. A car sitting in a climate control garage will hold up better than car sitting outside. Also, if the climate has 100 degree changes in temperature, that will make it harder on the components with all that expansion and contraction of the metal components. |
The car was indoors for probably 15+ years but the last few years of its life it was under a tarp in northern Tennessee.
No joke, there was a huge nest in the frunk when I got the car. Probably from an opossum! |
So the Motor turns over smoothly. I pulled the exhaust and there is a bunch of oil in the right side. The heads look oily inside so I am thinking it is in need of a head rebuild. So, if I am taking down that far I guess I will split the case and at least reseal it. Went ahead and got a Wrightwood gasket set. Look for my step by step rebuild in th near future.
Unless you have a definitive reason to split the case, I would just leave it alone and replace with new gaskets and reseal what you can... like chain covers, oil breather, etc... Splitting the case can cause old sealant material and other 'things' to come loose and fall inside, as well as moving everything out of alignment and making it 'out of round'. |
There is no certainty that the engine needs a rebuild because of this. Change the oil, empty the fuel tank, fill with new fuel (like 2 gallons). Circulate the fuel by bridging the DME relay. Empty fuel again and fill with new fuel. Try to start it. Fuel injectors might be clogged up if it doesn't start, if so send them away for cleaning or buy new ones. Run it a few hundred miles before considering a rebuild, partial rebuild. You won't do any more damage than there already is and nothing that a rebuild later won't fix. Starting a rebuild is a deep money pit to do it correctly and a budget "reseal" rebuild might not be better than what you have. |
So another quick question
While pulling the injection system off some sand (not a lot but some) fell into the head, What is the best way to flush it out? I thought about opening the valve and blowing air through the spark plug hole or flushing it out with diesel. Ideas? |
Shop vac will be fine , we have clean several ex. military vehicles with missing manifolds with a lot of sand inside the heads...
Good luck |
Thanks! |
I too am in the same boat in terms of, to split the case of a 3.2 or not. I purchased a Euro 3.2 with broken head studs, it sat for a number years in a shop with the heads off. The crank spins nicely and I know the history of the motor aprox 60K. Only a couple stud on the bottom broke. I was under the impression 3.2 cases were considerably more stable than mag 2.7's and would not require machining after splitting. I have new studs and I am in the process of getting the heads refreshed. Still stuck on splitting the case. Living on Kauai it is not like I can choose from a number of machine shops that have experience in 911 cases or have access to mechanics versed in air cooled engines. My concern is making sure the case if free of any debris etc. I have experience with assembling my 3.0 after a top end but I'm nervous about splitting the 3.2.
FYI, if any experienced engine builders would be interested "working vacation in Hawaii" to help with my 3.2 re-build I have free accommodations and an extra truck :). No major expectations just throwing it out there. |
work trip
I sent you a PM.Ciao Fred
Hawaii is tempting.....:eek: |
I rebuilt my 3.0 with zero Porsche experience and a few years later it still purrs like a kitten and has never leaked a drop of oil. Splitting the case is not a big deal in my humble opinion but it seems to scare a lot of people. I am not sure why, buttoning it up is not hard if you are organized and all of your parts are ready to go.
Haven't made the decision yet. |
Pulled the valve covers and the motor looks super clean inside. No broken studs and it certainly looks like a 65,000 mile engine. The outside is really cruddy so I think I am going to just change out all of the gaskets I can get to without taking too much apart once it is all together, clean the heck out of it and run it.
http://forums.pelicanparts.com/uploa...1568399334.jpg |
Yours is in much better shape than mine was! My SC was sitting since 2003http://forums.pelicanparts.com/uploa...1569129486.jpg
http://forums.pelicanparts.com/uploa...1569129486.jpg |
| All times are GMT -8. The time now is 03:00 AM. |
