Targa_PB_78_SC
mike sampsel's Avatar
Cam won’t rotate when heads torqued
Old cam rotates fine in assembly of heads and cam holder. Although it gets a bit sticky when 930 gets to 6 - 9 o’clock.
When the heads are torqued to 15 ft lbs, the cam won’t rotate. Wayne’s book says to try a different torquing pattern if this happens.
Questions:
1.) since I’m getting new cams, should I wait for those to do the head to head stud fastening?
2.) I’m supposed to swing 90 after the initial torque but wanted to test the cam rotation first. Maybe swing 90 and hope this fixes it?
3.) seems the cam should not bind at the 15 ft lbs first step, if this is correct, is there a more methodical correction technique other than just trying a different torquing pattern?
Old 09-02-2019, 11:45 AM
Verify that your old cam is straight, using v-blocks and a dial indicator. Then use a straight edge across the heads to check if one is off. Do those two things first.
Old 09-02-2019, 12:16 PM
kwikt 911's Avatar
Did you change cylinders? Heads resurfaced?
Old 09-02-2019, 04:12 PM
Targa_PB_78_SC
Heads were not resurfaced, cylinders were changed from 3.0 to 3.2 short stroke.
Old 09-02-2019, 04:23 PM
Questions:
Just curious, where does it say 15 pounds plus 90 degrees? Wayne’s book just lists a torque value...
Does the cam spin before it’s torqued?
Old 09-02-2019, 04:29 PM
Targa_PB_78_SC
The cam spins great prior to torque. I’m using Carrera cylinders with a taper seal torque.
Was told 15 # wait one hour then swing 90. But it’s not in Wayne’s book.
3.2SS top end rebuild - compulsory newbie questions
Old 09-02-2019, 05:05 PM
Targa_PB_78_SC
Well it appears the Carrera is 15 Nm then swing 90. Units! Doh. Not clear this would cause an issue with the cam turning difficulty though. I see the torque sequence in the bulletin is different than Wayne’s book too.
Old 09-02-2019, 05:46 PM
Nux Nux is offline
Nux's Avatar
15nm and then a 90 degree swing. It corresponds to about 40nm.
Old 09-03-2019, 12:23 AM
abit off center
cgarr's Avatar
Cylinders all the same height class? Base gaskets all the same and installed? Or the heads sealing surfaces are not the same?
______________________
Craig
G2Performance
Old 09-03-2019, 03:01 AM
Targa_PB_78_SC
Thanks for the thoughts Craig,
Checked and base gaskets there, same as all came in kit.
When I check the cylinder sealing surface, I can get a 0.16 to .2 mm feeler gage under the straight edge on both the number 2 and number 4 cylinder?
This tracks with my finding yesterday where torque to number 3 and cam rotates fine torque to outside nuts on number 1 and cam rotates. But torque to number 2 and cam won’t go in.
Old 09-03-2019, 05:46 AM
abit off center
cgarr's Avatar
That’s enough to cause a problem
Craig
G2Performance
Old 09-03-2019, 05:50 AM
Targa_PB_78_SC
Thanks again Craig, measured again with different edge (shorter) across cyl #2 but only adjacent lips of 1 and 3 and now 0.038 mm is the only feeler blade I can get between #2 and my straight edge.
Wanting to be sure of my issue before I start to correct it.
Old 09-03-2019, 07:20 AM
abit off center
cgarr's Avatar
.038 isn’t bad but .2 is almost 8 thousandths off
If you have a 3-4” mic you can check the heads see if they are off, should be around 84.5mm
Craig
G2Performance
Old 09-03-2019, 08:12 AM
Targa_PB_78_SC
Without seining 90, will I get an accurate enough measure to determine what cylihead gasket I might need to correct number 2?
4,5,6 is okay so I can leave it be while chances are made to 1,2,3 side?
Update Wednesday stardate ...
Some success (I think) I followed protocol on the 4,5,6 side and the right side cam spins like a top after torqued to 11 # and then swing 90 +- 2.00000 degrees. Ha.
Tried 1,2,3 again with protocol of service bulletin and after 11 # (but no swing) the cam won’t enter the journal nearest #3. Loosened nuts and cam goes in and spins like a top.
Time for some corrective action i say!
I doubt my heads are off as I had Bruce’s head guy do them. He (Robert said my heads were in great shape). He did no machining.
Suspect the Carrera cylinders are off and I’ll check gap after 11#. Gap between likely changed as I pulled up my cylinders to verify 101% that my case to cyl gaskets were there.
Old 09-03-2019, 10:11 AM
Simple math/geometry. The depth of the heads have to be the same as well as the depth of the cylinders have to match within .0015-.002'' per head and cylinder combined. Otherwise, the cam tower is bowed and binds up the cam. I just finished machining a set of cylinders to get the deck height I wanted. I used a Starrett depth gauge and leveling block to make and check my measurements. Bob
Old 09-04-2019, 12:32 PM
Targa_PB_78_SC
Interesting, those depth gauges are a bit costly.
Where did you find these tolerance numbers? 0.0015 - 0.002 inches?
Old 09-04-2019, 01:16 PM
I would rather be driving
jpnovak's Avatar
based on cam journal clearance. Too much bow and you pinch the clearance.
I have also cut the cylinder base to make sure all are the same height. Don't cut the tops. This will mess up the CE groove or top side taper (year dependent).
Old 09-04-2019, 02:04 PM
Ken911's Avatar
Ok so did you install the camshaft retainers and the gears? Sometimes if everything has been resurfaced, it will rub on the side of the camshaft retainer (93010519600). Because now the chain box is slightly too long for the new stack height. the cam will spin fine in the tower but not once the cover and gears attached.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 09-05-2019, 07:31 AM
My recall is years ago, struggling with this issue. I think I was out .003'' and the cam freedom was barely acceptable. I then think I opted for .0015'' for safety. A lot has to do with how much the cam and the housing bores are worn. Obviously the more wear, the more you can get away with. The depth gauge I have is a verticle ruler with fine graduations that sits in a base, with a slide that you work up and down the ruler. Drop the slide down to rest on what ever you are measuring, and read the measurement. A knurled wheel allows you to move the slide up and down in tiny increments. On mine, you can read it to .001''. Depending on what you are measuring, a lot has to do with feel. Bob
Old 09-05-2019, 01:17 PM
Targa_PB_78_SC
Working on it, I tested some snips from feeler gauge to prop up the head on the center cylinder.
Doing this to estimate what case gasket might work. So far I’m able to get the cam to spin with no resistance with all cylinder nuts torqued down to 11#.
Only shimed number 2.
Old 09-05-2019, 02:01 PM
