-71 T oil pump
Hi All, I'm currently restoring my -71T engine. It will be done to more or less stock spec.
1) Can I use my original oil pump or would you suggest an upgrade?
2) If I use my original pump. What kind of overhaul would you suggest? Is there kits available?
Thanks for any input
Jörgen Forssling
Gothenburg
SWEDEN
Old 09-30-2019, 01:21 AM
oil pump
If your pump is in good shape no problem.If you are upgrading to pressure fed tensioners you may want to upgrade.They drop your pressure a bit at idle and the oil warning light may flicker.Fred
Old 09-30-2019, 05:30 AM
Thanks Fred,
I'm not doing the pressure fed tensioners upgrade. I will just install the collapse stops.
So, what do I do to overhaul the pump?
//Jörgen
Old 09-30-2019, 06:17 AM
pump
Just inspect it and keep all the gears in same location.Look at the inside for any scratches and reassemble.Fred
Old 09-30-2019, 09:04 AM
