-   -   Chain sprocket alignment webcam question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1039808-chain-sprocket-alignment-webcam-question.html)
mike sampsel 09-11-2019 07:01 AM
Wonder if webcams (20/21) usually take the stock number of shims (3 left and 4 right)?
I did find I had four shims on each side at tear down. Gathering information before I align my chain sprockets.
Trackrash 09-11-2019 07:38 AM
I would start with what you had before. Then check and adjust as needed.
When I have changed cams in the past it did not change the number of shims required. YMMV.
