-   -   Fan strap insert with OP sensor in place? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1040593-fan-strap-insert-op-sensor-place.html)
mike sampsel 09-20-2019 12:00 PM
Following the book, finding it difficult to get my fan strap in place with the oil pressure sensor installed. Is it possible? I took my dizzy off can get it started on the 2,2,3 side. http://forums.pelicanparts.com/uploa...1569005965.jpg
Flat6pac 09-20-2019 04:26 PM
Loosen and lay the oil pressure sensor out of the way
Remember to retighten. Good time to put the AC support bracket in place with the fancy nut.
Bruce
mike sampsel 09-20-2019 06:53 PM
Thanks Bruce, I’ll look for the support bracket it had slipped my mind
