Back in the head stud game again.
http://forums.pelicanparts.com/uploa...1569276868.jpg
After many years not producing these , have decided to do this again. Years ago we made and sold these but stopped when our focus went away from the air cooled engines. Having got back into the air cooled business again, we took a look at this and saw that our air cooled engine projects could use a stud with our finger prints all over them. Some added features we did not have in the past are included. These are currently undergoing testing and hopefully into full production in October, available maybe mid October. Cost is still under review but expected to be competitively priced with others on the market. Are these better than anything else sold today. I would never trash another make or say our are better. They may have some features not available in others making the use easier, possibly. But our main purpose for doing this is to offer as many of our own signature parts in our engines as possible. If anyone else would like to use, we are making them available. As with all of our current parts, they carry our level of quality. We are also offering exhaust studs and case through bolts that will also act as a dowel at the split line, not requiring solid or hollow dowels to be fitted. The projects we are currently involved in have dictated the need for superior and lighter parts. To this end we are changing over all of the non critical engine fasteners to Titanium, including all of the perimeter studs, washers and nuts. |
What alloy family?
Sent from my SM-N960U using Tapatalk |
Nice combination of a rounded (bullet nose)top (so the washers and nuts will drop on easily) and a hex so they can be screwed in easily with a tool, especially after cylinders etc are in place.
Though I kind of like the idea of using finer threads with flange nuts for the top, which the SuperTec studs have. Same benefit for hitting the torque specs as with the case through bolts Porsche ended up doing. Easy to use flange nuts on the regular threads, though, so the benefit of not messing with the barrel nuts isn't bolt specific. (oops - found it) |
Wow Neil, those are gorgeous. I'll recommend those 100% to my case customers.
Love to see a set |
Intersted.
Upper threads are 3/8" x 24. This has pitch of 24 which is 0.042" and 1.0mm is 0.039". Its what would be commonly known as an imperial fine thread/pitch.
We went back and forth on what we should use and in the end went with the imperial size as these nuts are easy to find anywhere if you ever needed one quickly. The washers can either be stepped or flat with a serrated face to help with the friction. They will come in hardened steel or Titanium. Nuts are 12 pt and will be hardened steel or Titanium. |
We never tested a nut with a flange so the result of such a test is unknown. However, my thoughts would be that this would increase the friction more as there would not be any slip between the nut and the washer. I idea is to minimize the friction in the threads, nut and the washer and eliminate the shearing friction between the washer and the softer head material. Removing movement between the washer and head decreased the friction dramatically. The same can be said for the use of a stepped washer. This is my choice with these heads. The step eliminates the head from collapsing inwards towards the stud under compression. When this happens, the washer platform in the head concaves and the whole tightening function is compromised. |
Things of beauty for sure. Makes me wish I was building an engine.
While it might be tedious, could a person set up a dial indicator, with some kind of holder so it could be moved out of the way and back again without losing its register, so to speak, to measure the stretch from the tip of the stud?
Though once the variables are accounted for, the usual methods (which take those into account one supposes) seem to work well enough, at least for stock compressions. |
Neil,
Good to hear there will be another option out there for builders. I do like the hex on the top, certainly makes install a bit easier than using a stud installer. I do wish the top threads were Metric. For no other reason than consistency throughout the car. But, I do understand your reasoning behind your choice. Keep up posted with details as you get them back into production. Cheers |
"went with the imperial size as these nuts are easy to find anywhere if you ever needed one quickly"
Not in Europe :) |
Here are some better photos showing each end of the stud and the nut and washer. The nut and washer are made from titanium. We will offer a steel version if required. http://forums.pelicanparts.com/uploa...1569447268.jpg
http://forums.pelicanparts.com/uploa...1569447303.jpg http://forums.pelicanparts.com/uploa...1569447327.jpg http://forums.pelicanparts.com/uploa...1569447370.jpg The 964, 993 and the later water engines will be available also. |
Beautiful, Neil. Good job.
You know what would be a technology leap forward? Make the entire shaft hexagonal rather than round. Easier to screw in, and if it breaks...to screw out...
A departure from what is currently considered the "right way", is not to use any form of thread locker. The studs should be installed with anti friction grease and not bottomed out. Then any need to remove is easy. Misunderstanding and fear cause most to misuse thread locker on head studs. |
Anti-seize on the whole stud - the buggers are hard to get out, and if they get too hard to turn, you will torque them off - at least one. Hence, for instance, Stomski's tool to make drilling the broken stud out easier. If the nut gets seized, better to have the whole stud come out when taking your header off than to bust one off.
Or just put in dry. Any reasonable torque will keep the nut in place, although you can use the sort of distorted (copper color, slot in upper part of nut) nut VW and Porsche sometimes used in low stress applications. |
Yup, copper high temp anti-seize on the exhaust studs.
Funny thing about exhaust studs. Engineers know how to keep them from breaking off, they just don't do it in the vast majority of automotive applications, even in high temp turbo applications. Cat and Cummins class 8 engines bolt up their exhaust manifolds with longer studs and a 1-2" spacer under the nut. And they rarely break. |
Thanks. I didn't mean to derail the thread other than Neil mentioning the correct way to install studs. Typically, I do something and then ask. LOL!
Request - 3.6 through-case bolts ;) ARP gets $1K for theirs...
We are talking about hotter EGT's with studs being mounted into dissimilar aluminum. |
Exhaust stud breakage isn't limited to Porsche's, it's an across the board problem. Sure, turbo cars made it worse. When I was working at a multi-car line dealership, it was everything that had short studs. The only thing that reliably fixed it was long studs. Spacers if using welded tubes and flanges, cast in spacers if using cast iron manifolds. I'm sure that somewhere in there is the cost. If it made it out of warranty, the factories didn't see it as a problem. Just throwing it out there. If we're making a wish list of which hardware Neil should address next, exhaust studs should be high on the list. |
Thanks Neil!
" Cat and Cummins class 8 engines bolt up their exhaust manifolds with longer studs and a 1-2" spacer under the nut. And they rarely break. "
What I do. http://forums.pelicanparts.com/uploa...1570451110.jpg And, use nickel anti-seize, it has a higher temp rating than copper by a lot. Permatex copper is rated to 1800F, nickel to 2400F. Not sure where this copper rumor got started but I have read it several times and is simply not true, like a lot of stuff that you read these days. Also nickel on stainless is better than copper on stainless from a galvanic corrosion standpoint. Nice studs. So with the collared case through bolts they act like a shuffle pin? |
Exactly. But the installation requires some attention so the oil passage is not blocked. An update on the new exhaust studs, we have decided to make these in Titanium as this material has superior heat control. The head side will be 8.00mm x 1.25 but the nut side will be 5/16"x 24 so we can use our Titanium nut and washer combo. This material is used as an exhaust stud in many of our race engines that see continuous high RPM so we feel this is a good choice for this application. Common sense dictates installation, so will require the use of anti seize grease which we will provide and a torque value of 18 ft/lbs. |
Any chance of using a metric fastener on the nut side? Staying consistent throughout the engine and vehicle may be a good choice. It is the path others chose in the same market place. If you are using SAE fasteners I would assume readily available, hence the choice? Unlikely "our titanium nut and washer combo" is produced just for you, given the volume. Metric fasteners in the same grade surely are available as well?
At any rate, I certainly tip my hat to the research and thought that goes into ensuring the product and materials function as well, or likely better, than intended. Which I am confident they do. Cheers |
We use these nuts on many other engine applications and choosing the nut was about covering multiple uses. Making 12pt Titanium nuts is expensive over steel as the process is done with heat and not cold. This requires more expense so we look how best to we can have our cake and eat as well. I hate to do this, but anything we are about to produce in Titanium bolt and stud wise that requires a nut is coming with an SAE thread. Same reason. I'm looking function over thread size. """Also I'm in cahoots with your Snap On guy to sell more SAE sockets and wrenches.""" |
And then we start using Lucas electrical systems!
Neil, I sent you an email about purchasing a set of these exhaust studs
| All times are GMT -8. The time now is 10:35 PM. |
