-   -   Exhaust studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1040927-exhaust-studs.html)
mepstein 09-24-2019 12:04 PM
Exhaust studs
Little help please. What length stud for early 911 exhaust. Coarse or fine thread. Zinc or stainless. Thanks.
Some of the studs on my Carrera engine easily unscrewed while I was removing the exhaust so I’m not anticipating a fight but I will remove carefully and chase the threads for new studs. The engine is on a stand so nows the time to do it. If I do run into problems, our shop has a Stompski kit. I’m using a thin flange exhaust so I’d rather have the correct length studs than use spacers.
Flat6pac 09-24-2019 05:21 PM
Try 8x37.
999.062.006.02
Bruce
mepstein 09-24-2019 05:55 PM
Thanks Bruce. Should I do zinc coated or stainless steel. I’m getting a bunch of hardware from bell metric so I want to include these in the order.
Jonny042 09-25-2019 06:34 AM
I'm fitting early style (Eisnemann) HE's to my 3.2SS - I got studs from Belmetric. The 3rd pic shows them on the right compared to a "normal" stud on the left.
http://forums.pelicanparts.com/uploa...1569418300.jpg
You want zinc. Stainless will gall and be a general pain in the rear.
mepstein 09-25-2019 07:05 AM
Thanks. I confirmed with another expert and he said zinc coated as well.
