911 piston orientation
I’m disassembling my 1974 911 2.7 for a rebuild, and documenting as I go. I believe the #1 piston was installed upside down when it was rebuilt many years ago. All the pistons have the hump pointing towards the fly wheel except #1. Please take a look at the picture and let me know if my suspicion is correct. I want to make sure I get it right when I reassemble the engine. Sorry the pic is upside down.
Senior Member
Yes all should be the same. You should pick up Wayne's book on rebuilding and modifying 911 engines.
You’re right on #1 cylinder. the concave area is by the spark plug when you build 2.7 to 3.2
Bruce |
Thanks for confirming.
How about the other side?
Do you a picture of cylinders 4-5-6? When your are looking or facing at these cylinders, the hump should be on the left side of the CIS pistons.
Tony |
4 5 6 side
