cross arm for door window
hallo,
i am trying to install a new cross arm in a porsche 911T from 1973.
but the arms of the new one are about 5 cm longer then the original old one ??
I am not able to install this arm correctly .
Can somebody give me a tip how to do?
thanks
Ricardo
Old 10-06-2019, 05:34 AM
Is this thing called a "cross arm" something I never heard of in an engine?
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 10-06-2019, 05:41 AM
Are you asking about the window regulator ? If so , the new regulators require new holes .
Old 10-07-2019, 08:29 PM
E Sully's Avatar
I replaced the original regulator in my 1973.5 about 20 years ago. The updated one came with measurements to drill a few new holes. You should check to see if you have the paperwork with the new hole locations. My updated one is working perfectly.
From Pelican catalog
Note:
When replacing parallel with cross arm type regulator must also use (Qty.) (1) 911 542 057 00 rail (1) 911 542 491 40 seal. Left. Coupe. Fits left of vehicle
Ed
1973.5 T
Old 10-10-2019, 11:08 AM
ED,
herewith a picture of the mechanisme
Richard
Old 10-15-2019, 07:20 AM
