spark jumping out of coil to ground ?
Have a freshly rebuilt 2.0 liter with new distributor cap, wires, points, though older used 12v coil from USA. Ran well first 200 miles. Yesterday I notice with engine running, a steady spark jumping out of coil "outlet" nipple and shorting over to either/ both positive & negative posts. Engine continues to idle though.
Any guesses as to why brand new parts are allowing this to happen. |
Suspect your distributor not aligned correctly ... check where rotor is pointing at TDC.
| All times are GMT -8. The time now is 06:48 PM. |
