Cylinder heads before and after
This is my second set of cylinder heads rebuild by
JB Racing in Tavares, Florida. They have all the necessary tools and know how. Price was $ 1400.- with new guides, seals, some new studs and all the labor. Blasted and all. http://forums.pelicanparts.com/uploa...1571345402.jpg http://forums.pelicanparts.com/uploa...1571345402.jpg http://forums.pelicanparts.com/uploa...1571345402.jpg http://forums.pelicanparts.com/uploa...1571345402.jpg http://forums.pelicanparts.com/uploa...1571345402.jpg |
Any new seats or valves required?
Cgarr on here does this too... roughly half that price...
May just be the resolution of the pictures, but was the head to cylinder mating surface machined or just bead blasted?
Cheers |
OP, I'd take the heads back and have the surface machined. If I'm not mistaken, that is a tapered cut. |
Cylinderheads
Early cylinders had gaskets to form a seal.
The lip is only to center the cylinders on the heads. |
hbrand,
Where new studs were installed are they heli-coiled?http://forums.pelicanparts.com/uploa...1571412484.JPG |
Looks like a time-sert they work great for those areas.
Craig.
There’s a vicious rumor going around that you may be contemplating retirement. While I’d be happy for you, if you are could you delay it for a few months. I have a 3.0 I was going to send for machining and afterwards a 2.7. Fun fun!! Thanks Tony |
As long as my health holds up which it should I will keep working a long time. I am 60, I kind of promised my daytime employer 8 years plus a lot of my equipment is here. Its actually kind of nice I keep their machines running and I get a nice shop, plus health coverage then I slide in the head work etc.
Whew. That’s a relief.
Thanks Tony |
Cylinderheads
Here is the detail for the work on the 6 heads:
PORSCHE 1966 2-LITER HEADS 0.00 0.00 Labor 250.00 Disassemble, Clean, Bead Blast Heads and Valves Labor 180.00 R & R and Fit Valve Guides 12 10.00 Parts Valve Guides 12 5.00 Parts Valve Seals Labor 300.00 High Performance Street Valve Job Bead Blast Springs, Retainers and Pans, Set up Valve Spring Shimming and Assemble Heads Labor 300.00 Time-Sert thread repair on six exhaust studs Install new studs 200 |
cylinder heads before and after
Plus plus plus for Jim and the folks at JB Racing. They did a phenomenal job of machining for a 3.4 I am building.
Pricing is very fair and Jim is extremely knowledgeable and informative. |
| All times are GMT -8. The time now is 01:37 AM. |
