Throttle cable to TWM itb's
Anyone happen to have any pics of how you connected 993 throttle cable to twm throttle bodies and bracketry to hold throttle cable?
http://forums.pelicanparts.com/uploa...1571418010.JPG |
Or any pics of throttle cable connections to TWM itb's. thx!
On the Jenveys we use, we run a cable from the gearbox bell crank up to the throttle housing. But, the Jenvey's are set up for a cable and the 915/G50 in the G body cars have the bell crank. We use an off the shelf adjustable adapter to attach the cable to the bell crank and fabricate a simple bracket to anchor the cable sheath at the gearbox end.
We are just sorting out a similar issue with a 964 build that of course does not have the bell crank on the gearbox... Cheers |
| All times are GMT -8. The time now is 03:11 AM. |
