Engine ID help
Good afternoon,
Found a wrecked 76 w a 930 kit with a Carreras motor . Am I sure it's a 3.2 motor 930 105 111.1 R and if I was to order parts ,how do I identify it ? 84 Carrera? Any help would be much appreciated. Thanks, |
I would start with posting the serial number and go from there.
Look for the numbers stamped in the case near the fan shroud. Even then, it could have been rebuilt into something else.
Thank you
Will do when I get home .... thanks
calls for some PEECHURS too!
| All times are GMT -8. The time now is 10:19 AM. |
