3.4 Dyno Chart
Just wanted to share the lasted dyno chart after final tuning. The motor is a 3.4. The great torque curve is courtesy of cams from John at DRCamshafts. We have used these exact cams in a couple of other 3.4 builds and love the power/torque curves.
http://forums.pelicanparts.com/uploa...1571890484.jpg Cheers |
Jeff,
I got a similar shaped curve with John's 993SS cams in my 3.4 build. Only difference to your build is that I used the standard 3.2 intake manifold and consequently lower peaks of course. Similarly I used Motec/twin plug/CoP/twin O2 sensors/twin knock sensors/AFM delete tube/1 5/8" BBE's/Dansk Motorsport muffler/Mahle 10.3:1 98mm. It's great to drive in the Twisties. What is the spec of the cam you used? |
Really impressive - I achieved similar figures on my 3.45. Similar setup except for using 1.65” OD headers
Since it is showing uncorrected, what temps were this engine ran in?
Very nice....
I have a stump or two on the property. I was going to use the Tundra but ????? |
Very nice shape to those power curves. Love the flat torque curve. Looks like there are some more rpms in that beast.
We have another 3.2SS on the dyno right now, then sending out latest 3.8 over there as well. |
We ran out of injector... It could spin 7200 reliably I feel, but we limited it to 7000. With a larger injector we would seen north of 300 at the wheels. cheers |
That is awesome. Great build!
That's a V-8 torque curve. Very nice. How does it drive?
We have built this combo a few times and just love the torque. We have a 3.2SS ITB motor on the dyno getting final tuning right now, then the 3.8 ITB one will be on the dyno hopefully late next week. Just putting some break in miles on it before final tuning. Cheers |
Great job on this build Jeff!
Love it, such a good promise for my 3.4 build...almost the same spec except for PMO's, Eisenmann exchangers and DC35 cams....
If I can get that torque curve even with 10% less HP and torque I will be delighted..... Dennis |
which injectors were you using?
Any reason to go with 98mm pistons over 100mm? I am having an engine built and thinking 3.5? Also struggling with ITB selection, as there are a number of choices. I want something easy to maintain over all else.
I have a 915 box (engine will be in a 71T) ... stock gear ratios seem fine; any sense in re-gearing it closer / shorter? With this torque it would seem not. |
| All times are GMT -8. The time now is 03:39 PM. |
