What's this noise? Newly rebuilt 930 engine.
Finally got this 76 930 engine back in and running (thanks to those that helped me overcome other issues). After about 45 miles, I now hear this gawdawful noise coming from the engine. Occasionally goes away-seems to lesson as the engine warms. At first I thought it was a loose timing chain or the fan bearing. This engine has the hydraulic chain tensioner upgrade.
I pulled the timing chain covers off to look at the tensioners/chain, but both looked good and tight. I can't move the tensioners in our out with my hand alone, but can by prying with a screw driver, but they're pretty stiff. Nothing is loose. I turned the engine by hand and can't hear anything dragging. Unless someone has an idea, I guess my next step is to remove the valve covers for an inspection, and then pull the engine the rest of the way out and dive back into the case. Listen to it: https://www.youtube.com/watch?v=SgYtetX1QSs&feature=youtu.be Thanks for any help, Bob |
very odd, sounds like an irregular clatter...
Disconnect the fanbelt, this rules out alternator issues. Other than that, valve covers off and make sure valves not bent... Sorry, good luck... Wonder if valve timing could cause it to run that rough? |
The video kind of sounded louder near the fan and distributor. either one of those could be a source of noise and not a huge problem. Get a mechanics stethoscope and poke around in there until you find the source. There's quite a bit of oil in the triangle of death, and a random loose copper washer... Probably not related to the noise, but may be some additional things you need to clean up / address.
Could not get a fix on the noise, but a worn out dist shaft with create quite a racket. The pop off valve can create odd sounds when it is worn out, but I think that happens primarly under load and throttle open and closed.
sounds valve or rocker related. Put the washer back on the oil pressure switch while at it. Will fix the oil leak back there.
Chris |
and get a hose or a pair of mechanics stethoscopes and localize the noise |
Obviously not what you want to hear on a rebuild.
There are many sources of noise. Could still be tensioners. That rattly sound seems like poor operating tensioners My experience was rattly sounds after first 30 miles. Pulled engine and replaced one tensioner. Also looked at the cam sprockets and changed the number of shims to better align the whole chain path to the intermediate sprockets. Sounds disappeared. 15,000 miles later. Still no sounds. |
During the first rebuild I also polished the shafts that hold the idler arms. They had bushing material smeared on them. Replaced one of the two idlers because the bushings were out of spec.
I did not want any binding or sticking between the idler arm and the pivot shaft. |
I’ll pull the distributor and check for play at the gear. This engine only had 40k miles on it, so don’t expect a worn out shaft. All new washers and fittings at the oil leak and wasn’t all that tight. Gave it 1/8 turn, so expect that to help.
I did try holding a large screw driver on several places with my ear on the other. It was damn loud every where! I’ve already checked/adjusted valves after run in and didn’t notice any valve train issues. Since the engine is halfway out, I’ll pull the covers back off and inspect again. Not sure how I would spot a bent valve? Let me know how. It’s a low compression 930 engine, for some reason I didn’t think it was an interference engine. Kind of hoping it is a loose rocker at this point-heard of them coming loose before. I have a borescope for my phone and checked back behind the timing chains to ensure they weren’t rubbing on the housings. Pop off valve? Don’t think I have one. Hope to do some work on it tomorrow. Appreciate the ideas. Keep’em coming. |
Take some more pictures of the various parts you are inspecting. Like the tensioner, idler gear clearance
But this is a 1976. They did not come with factory hydraulic chain tensioners. Did someone add them? I reread the OP. And yes it has them. Also a leak down test will confirm things like bad valves, heads, rings. Depending on the level and sound source if there is leakage you will know. |
Same piston and cylinders and rods? A bent valve will not necessarly make a noise, but will miss fire and pop back and you can determine with a leak down
All same pistons, cylinders, and rods except one piston/cylinder. Original cams/rockers except one rocker. I weighed new piston/rod set and matched weight with others.
I'll add the leak down and compression tests as soon as I get back out to the shop. |
Ok this is embarrassingly one of the more bone headed things I have done but easily duplicated. Did you screw the oil line into the correct hole to feeds the tensioners? Yes there are two holes on the tensioner cover where it screws in perfectly. Don't know what the second one is for but it fits like a glove. No oil to the tensioners will make that noise.
Chris |
Verified timing Chain oil lines connected correctly.
I performed a leak down test. #1-1%; #2-3%; #3-0%; #4-1%; #5-0%; #6-16% ! The air escaping #6 could be heard coming out the exhaust. Good chance this is the culprit. Next step is to pull the right side exhaust valve cover and inspect. Gosh I'm hoping for something simple! Stay tuned. |
You didn’t drop a nut down that cylinder? |
Pulled exhaust valve cover and nothing obvious. Was hoping for a loose rocker which was allowing the valve to close all the way and was making noise. With 6 @TDC, valve clearance “feels” normal (didn’t measure yet).
I’m afraid I may be at the point of further disassembly. Might be best to go ahead and drop the engine completely?? |
Do a leakdown or compression test first...
Do you have access to a video bore-scope?
Yes, I have a bore-scope.
Someone suggested removing the fan belt in order to discount the alternator. ?
The noise seems consistent with crank rpm, not cam rpm. When you did the differential pressure test what did plug 6 look like, any signs of being impacted by debris? Perhaps, with the plugs removed turn the engine over by hand And see if there is a tight spot as though something is between a piston dome and head. |
I did remove all plugs and turned engine by hand. All smooth no indications of problems, no noises, chains didn’t flex the tension eta, etc.
All plugs black and somewhat sooty. Kind of expected it since the AFR’s for this turbo engine is a little richer than what I’m used too with N/A American V8’s. Not wet, damaged,-just black. Spun the alternator, it’s smooth with no apparent problem. Plan on sticking the bore-scope into the no. 6 spark plug hole tomorrow. |
Is it louder near the bellhousing? Any chance that the flywheel or clutch is loose? Is it the correct clutch for your trans? It doesn't have that rhythmic, consistent sound of a rod/piston/main bearing noise. It seems more random.
sounds to me its on the right side valve trane. Spark plug wires routed correctly? timing correct? Cam timing correct? getting oil? valves adjusted correctly? is there air flow out from the oil filler indicating blowby?
really has to be one of these things. |
You said it ran fine for 45 miles. Did you over rev it? Turbo wastegate working properly (did not over boost it). has the airfileter on? Running the right gas?
Chris |
Pulled the engine/tranny rest of way out.
FLYWHEEL WAS LOOSE!!! Each of the six bolts were loose. I would have bet anyone a good chunk of money that I lock-tited them, but forensics say otherwise. All bolts and holes look good and not "wallered" out. Now I have to chase the leakdown on the No. 6 exhaust valve. I couldn't see anything with the bore-scope. It was too big to look at anything except straight in the spark plug hole. First thing is to remove rocker and then see if I can get the valve springs off for inspection with the head on. At this point, I'm hoping for a broken/cracked spring that is not pulling the valve up; however I'm not very hopeful. I kind of think that the 100 psi air I used for the leak down test would have seated the valve. Going back out later tonite. |
Hook up your leakage tester to #6 then with the lower valve cover removed tap on the rocker with a plastic hammer while watching your gauge and see if it improves. Could be a tiny particle dislodged while removing the spark plug.
Glad u figured it out
Chris |
Glad you got it figured out! It sounded too random to be crank or cam speed related.
Starting a new thread for the #6 cylinder leak down issue.
http://forums.pelicanparts.com/porsche-911-technical-forum/1044142-no-6-cylinder-leak-down-problem.html#post10644172 Thanks for all the help so far! |
You need to very carefully inspect how much material has transferred from the flywheel to the crankshaft. I would guess you will be scrapping one or both pieces. It's really hard on the interface surface to run loose. Especially check the surface where the flywheel is a slight press fit. This is definitely not the first 6 bolt flywheel to come loose. Search other threads, but I believe there is some talk about it being permissible to over torque those fasteners *ive only owned 9 bolt porsches, so I am not an expert here*
And when you put the red loctite, apply it to the female threads before you install the flywheel. The idea being to make sure none of its makes its way in between the flywheel and the crank - it can cause false torque readings and facilitate things coming loose later when the stuff breaks down.
I'm told the Loctite can still wick between the mating surfaces, and that the preferred way for flywheel bolts is to apply to the female threads. I'd guess that most people do similar to what you describe though. |
| All times are GMT -8. The time now is 06:18 PM. |
